Chevrolet Venture Emergency Brake Click
KIMSCHEVY
I had my e-brake engaged, upon leaving, i disengaged the brake and started to drive away, there was a clicking noise coming from the area of the brake on the inside of the vehicle. It gets louder the faster i drive. I tried to engage and disengage the brake several times to see if that would stop it, but it did not.
Apr 15, 2007 at 8:07 AM
ROCKWOOD84
  • 103 POSTS
the emergency brake was designed to engage when you mash on it once to disengage you push it back down again and let off . something must have broke inside the drum. either take the tire off and pull the drum off each side to see what it was or take it to a brake repair.
Jul 14, 2007 at 10:03 AM
Suggested Repair
Remove each rear wheel and brake drum to inspect the parking-brake mechanism for a broken part, or have a brake shop inspect both sides.
Conversation Summary
After the emergency brake was released on a Chevrolet Venture, a clicking noise from the brake area grew louder with speed and did not stop after cycling the brake. The expert said the pedal should be pressed once to set and pressed down again and released to disengage, and that something likely broke inside a drum. They recommended pulling both drums for inspection or taking the vehicle to a brake shop.
