2001 Chevy Venture Vehicle will move on an incline when in
2001 CHEVROLET VENTURE
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
HANSC85
The vehicle will not hold in the park position. i.e when parked on an inclined driveway, the vehicle will move down the slope. So I have to use the parking brake. How do I fix it? How much will it cost approx?
Thanks,
Apr 21, 2008 at 3:04 PM
MOPARNUT1393
  • 34 POSTS
[quote:db0d0f58a3="hansc85"]Transmission problem
2001 Chevy Venture 6 cyl Two Wheel Drive Automatic 112000 miles
Thanks,[/quote:db0d0f58a3]
one of two things come to mind...1. shifter linkage is wore out and may not be putting transmission into park or two parking pin has broken and then you will have to have a tranny tech go in to it but id go with number one first.
Apr 21, 2008 at 3:29 PM
DENNYP
  • 1,824 POSTS
If the shift cable is adjusted properly, then the problem is in the park pawl or internal park linkage.
Apr 29, 2008 at 2:58 PM
