2003 Chevy Venture ABS Traction Off
170,000 MILES • 6 CYL • FWD • AUTOMATIC
MWINSBORROW
The ABS and Traction Off light is on. There is a brake squel however we have 80% brakes on the front and 60% on rear.
Hope you can help.
Best Mark
Jun 26, 2010 at 11:24 AM
SATURNTECH9
  • 30,869 POSTS
Find out what code's you have in your abs computer and i will get you the trouble tree's for them.See if you can maybe rent a abs scanner from a auto part's store.As far as your brake's squeling the brake's could just be glazed or you might have put on cheap brake's when you had them replaced last.
Jun 27, 2010 at 5:15 AM
