My power window is dead, How can I raise it manually
Sep 25, 2010 at 7:53 AM
SATURNTECH9
✓Experienced Mechanic
If it's a bad motor you might be able to remove the inside door panel and tap on the motor while you move the switch to the up position.That work's sometimes if it's a bad motor.
