1998 Chevy Venture Van thermostat
KEVIN0113
  • 1998 CHEVROLET VENTURE
Engine Cooling problem
1998 Chevy Venture 6 cyl Automatic
where is the thermostat located exactly and how do you change one.
Monday, December 14th, 2009 AT 11:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable.
Partially drain the cooling system into a suitable container, to a level below the thermostat.
Disconnect the radiator hose from the thermostat housing.
Unfasten the thermostat housing bolts.
Remove the housing. Note the installed position of the thermostat, then remove the thermostat and gasket.
Thoroughly clean the gasket mating surfaces.
Friday, December 18th, 2009 AT 7:30 PM
HAHNY1
  • 75 POSTS
We had the same problem. Is there a trick to getting the bolts out and will it come out, looks like the fuel rail might be in the way
Friday, February 19th, 2010 AT 7:41 PM
