1998 Chevrolet Van Misfire P0300
RICK47
You gave me some ideas a couple weeks ago but still misfiring.98 chevy van 2500 5.0L 102k miles. It's the one I replaced the head on & when I got it back together cyl. #2 & #5 don't seem to be working properly (p300 code), compression was 160 & 165. I'm getting spark(replaced coil), pulled & and cleaned injectors switching #2 & #5 with different injectors ,could the valves be adjusted wrong(I checked several times)or could those two injectors just not be getting power or am I overlooking something simple. Thank in advance for any suggestions.
Mar 18, 2007 at 2:12 PM
  • 75,988 POSTS
A P0300 indicates a Random MIsfires
The cause is typically a vacuum leak in the intake manifold, throttle body or vacuum plumbing, a defective Exhaust Gas Recirculation (EGR) valve that is leaking exhaust into the intake manifold, or even bad gasoline
Mar 18, 2007 at 3:20 PM
Suggested Repair
Check for vacuum leaks at the intake manifold, throttle body, and vacuum lines; inspect the EGR valve for exhaust leaking into the intake; and verify fuel quality.
Conversation Summary
The owner of a 1998 Chevrolet Van 2500 5.0L reports continued misfires on cylinders 2 and 5 with a P0300 code after a head replacement. Compression, spark, and injector swaps were already checked. The expert says a P0300 indicates random misfires, commonly caused by an intake vacuum leak, a leaking EGR valve, or bad gasoline.
