Bank 1 Sensor 3 & Bank 2 Sensor 1
CHEVROLET
COYOTEDEB
[b] :roll: Very confused...I took my Chevy Van 1996,V8.........120,000 miles to get Inspection/Emissions it failed, the guy said I need the following.........Bank 1 Sensor 3 and Bank 2 Sensor 1 What the heck are they and is there another name for them and what do they do.......can they be bought at an auto parts store or does it need to come from Chevy Dealer[/b]
Dec 6, 2006 at 12:49 PM
GARFIELD
  • 197 POSTS
First sensor bank 1 sensor 3, I have never heard of sensor 2. Normally bank 1 is the drivers side and bank 2 would be the passenger side. Sensor one is the one that is before the catalytic converter and sensor 2 would be the one that is just after the converter or actually mounted to the back of the converter. Your van may have two converters per side and sensor three would be the one in the second converter. Before you change you oxygen sensors try and clean the connections with electronic parts cleaner. You may want to do the same for the tip of the sensor after you take it out. You can generally pick up the sensors at most auto parts stores for between 50 to 150 dollars each, just stay away from the universal sensors buy the OE connector style for ease of installation(simple unplug and replace the sensor then reconnect the connector and you are done.
Dec 6, 2006 at 1:03 PM
