Several Related Issues
DCARLTON
Hopefully this one is an easy one. 1993 G20 Chevy Van, 173,000, 5.7 v8, conversion van by Tiara.
Several months ago, after driving the van about 5 miles away, my wife called and said several things just quit working. These things are:
Power Windows, AC/Heat blower fan, speedometer, ABS Light stayed on, transmission locked into 2nd gear, service engine light. Code for is indicates it can't sense actual speed. I drove over, poked around a little, and ended up driving it home. Later on, was looking around at fuses and such, and wiggled this big black module inserted in bottom of fuse block (part # 225294441 2336 Invotronics). Things went to working again.
Well, it's done this a couple of times since, and my repair has been the same, thinking that maybe this thing was getting knocked by a foot or something. Well it happened this weekend and no matter what I do, I can't get it fixed. So the first question is, is this big black module a fuse or part of the problem or am I wiggling something else that's fixing this when I mess with this black module?
Sep 3, 2007 at 7:49 AM
DCARLTON
Still fighting this issue, but here is what I know. That black module supposedly has nothing to do with the problem as the mfg of the module says it is simply a module that has a bell in it to tell you when the keys are in the ignition or the doors are open.
I have the whole thing apart in my garage tracing wires and such. I have found that on certain fuses in the fuse block, I am not getting power to them. Of course these fuses are marked for the items that are not working so it would seem power to the fuse block is the problem. Have checked the various hot leads coming from inside the engine compartment and they all appear to be hot after the fusible links which seems to discount them as a problem.
So the new question is where do I look to find why I am not getting power to certain parts of the fuse block?
Nov 3, 2007 at 5:36 AM
DCARLTON
The good news is, I think I may have found the problem but I won't know for sure until after tomorrow. This past Saturday, I was working on it and tried to crank it, but of course, it had been sitting for a while and needed jump starting. It did without any trouble. I checked the battery with my meter and it was only showing 10.5 volts, no surprise there. I then decided to check on the output from the alternator to the battery with the engine running and was still only getting about 10.5 volts.
I thought, maybe, just maybe this was the part of the problem, hoping it would be all of it, but knew better than that. I took the battery and alternator up to the auto parts store and had them check them out and they both checked out bad so I bought a re-manufactured alternator and a new battery.
Got them home, reconnected everything and to my surprise, was only getting 11.5 volts to the battery when it was running. I thought maybe, just maybe the alternator was bad, but before taking it back, I decided to check the main output wire from the alternator to the battery while running and was also getting 11.5. I then disconnected it all and checked the main output wire to the battery and was still getting 11.5. I then checked the regulator wire with the engine running and was getting 11.5. With the alternator out of the loop though, when I turned the ignition to on, the AC/Heat blower began blowing and my electric windows started working. I thought this to be interesting.
So, I took the alternator back and they checked it out and it checked out fine; no problem. They were puzzled why it wasn't working in the van and also were puzzled about the accessories suddenly working. I brought the alternator back home and hooked it up and still got the same results, about 11.5 volts with engine running. I also noticed though that sometimes when I cranked it, the AC/Heater blower would work, sometimes it wouldn't.
I then began looking at the wiring harness on the steering column, remember, I have the whole dash loose/out and the steering column is dropped. With the ignition on, I could wiggle this wiring harness on the column and the fans would come on and go off. Also the power windows would work fine; I suspect that if everything else was connected, it would work too. This harness is the ignition switch according to Chevrolet and looking at it, you can see it has a burnt spot and the connector is weak in some places. It got hot at some point in time. I have ordered this part and it will be in , in the morning.
Well my testing is done since I don't think I can crank it although I may try later and move it into the garage. The parts guy says that this will cause electrical issues like I'm experiencing but should have no effect whatsoever on the alternator issue.
So there's the bad news, I may have found the original problem and may have it fixed, but in doing so, I have found the alternator is not working even after replacing it. Any ideas on the alternator? Could the ignition switch interact someway to keep the alternator from producing voltage? I know it seems unlikely, but there's not much to the alternator hookup, certainly a lot less than what I've been through so far.
Nov 5, 2007 at 3:58 AM
