1999 Chevy Van Engine ran with out oil
90,000 MILES • V8 • 2WD • AUTOMATIC
DONBROWN
After the radiator was replaced, the mechanic failed to correctly connect the oil cooling line that runs from the engine to the radiator. All the oil was lost and after a few minutes the van engine died. When the oil was replaced and the line was correctly connected the dealer reported a significant drop in the oil pressure. After driving the van for a few hours the engine seized and the crankshaft failed. The mechanic thought the damage was caused buy his failure to correctly connect the oil line and the resulting running the engine without oil. Did running the engine without oil cause this damage?
Apr 13, 2008 at 3:04 PM
  • 31,937 POSTS
Hi there,
yes,
running the engine with out oil will cause it to seize up, even if the oil is re filled more often than not the damage has already been done, as the bearings would over heat and start to get pounded by the crank, it wont take much to start to block a oil supply hole and seize the engine.
Mark (mhpautos)
Apr 13, 2008 at 3:35 PM
