What is the fuel pump pressure and how to check for it on a 5.7 liter with throttle body injection.
Thursday, February 19th, 2009 AT 2:48 PM
JDL
MECHANIC
Hello, can you give us the model of your van? It may not matter, with TBI, it is usually around 10 psi.
You'll have to tie into the supply line, if there isn't any schrader valve.
SPONSORED LINKS
Thursday, February 19th, 2009 AT 3:09 PM
BARLOE
MEMBER
The Chevy Van is a G30 1 ton with a 5.7 liter and throttle body injection.
Thursday, February 19th, 2009 AT 6:42 PM
JDL
MECHANIC
Fuel pressure 9-13 psi. If there is no schrader valve on the fuel line, I didn't see one, you need a tbi fuel pressure gage, tie-in the supply line at throttle-body. Be careful about pressure on the system.
