Chris,
I checked the EST wire and the Grounds both were ok for continuity. Went and got a PCM. The truck started roughly, timed at 0 degrees. Thats with the EST plugged in, but when I put it in reverse and put a load on it the truck has power then starts chugging and sometimes dies. It is closer but still not quite right.
The rough start is odd, it will crank normally and then it tries to drag, at times it will spin over fast.
Any more suggestion?
Also took if for a ride up the street but only made two houses.
Cleared codes and have a code 12
Having to retard it to get it to crank normal
and advancing to get to run. But no power to run.
SPONSORED LINKS
Thursday, January 25th, 2007 AT 4:05 PM
