1986 Chevy C10 White Smoke and Oil Leak
Have some one start it up and raise the rpm to 2500- look at the engine. Probably its still leaking oil and dropping on the exhaust manifold-look behind the distributor and front of the intake-
Something tells me that the rubber gasket slip off or the end to it is not sealedwhen re-installing the intake manifold
Try retorquing it down follow the correct pattern and ft lbs.
That's the only plact it will leak oil from unless you your rear seal is gone. Gotta look at it good.
Suggested Repair
Inspect for oil leaking onto the exhaust, especially the valve cover gasket, intake manifold end seals, and the oil pressure sending unit beside the distributor. Recheck the PCV valve and retorque the intake in the correct pattern. If those areas are sealed and oil still leaks, inspect the rear main seal.
Conversation Summary
The owner of a 1986 Chevy C10 with a 350 reported heavy white-to-gray smoke while driving, plus severe oil leaks on the driver side and behind the engine, after replacing valve cover and manifold gaskets, plugs, wires, and oil. The expert advised checking the PCV valve, engine temperature, oil dripping onto the exhaust, intake end seals, and retorquing the intake. After the smoke continued, the expert pointed to the oil pressure sending unit, valve cover gasket, and possibly a failed rear seal. The owner later said it was fixed but did not identify the repair.
