2000 Chevrolet Silverado Flat Spot
BUCKEDRACKETEER
hi i own a2000 chev silverado 4x4,4.8L engine with 195000km,s on it.it has a very pronounced flat spot on acceleration.i recently replaced the fuel pump,fuel pressure regulator and performed a tune up.any suggestions ?
thanks
Sep 18, 2007 at 12:27 PM
  • 75,988 POSTS
[quote:8be6f112de="buckedracketeer"]hi i own a2000 chev silverado 4x4,4.8L engine with 195000km,s on it.it has a very pronounced flat spot on acceleration.i recently replaced the fuel pump,fuel pressure regulator and performed a tune up.any suggestions ?
thanks[/quote:8be6f112de]
For a start check the throttle position sensor it takes the place of a carbuerator accelerator pump. Could also be the oxygen sensor getting lazy or a MAP sensor.
Sep 18, 2007 at 12:49 PM
Suggested Repair
Check the throttle position sensor first, since it can cause a flat spot on acceleration. Also consider a lazy oxygen sensor or a faulty MAP sensor.
Conversation Summary
A 2000 Chevrolet Silverado 4x4 with a 4.8L engine and about 195,000 km has a pronounced flat spot on acceleration. The owner already replaced the fuel pump and fuel pressure regulator and performed a tune-up. The expert suggested checking the throttle position sensor, and also considering a lazy oxygen sensor or a MAP sensor.
