Compressor, drier, orfice tube are new. System has been flushed and evacuated for 2 hours. 28 oz. of freon and PAG oil. Problem - a/c temperature at idle is fine (40 degrees) but rises toward 50 degrees when RPM's are raised during normal driving. Do you have any ideas? a/c is just not performing at peak performance. Thanks!
2001 Chevy 1500HD AC Warm at Speed
high side - 290 on a 92 degree day. Low side - 52
With rpm's - high - 260
low - 45
I even tried to lower the freon level but I think my low side is still too high. Shouldn't it cycle between 25-40. Used a new GM compressor and it does cycle, just not in the right range. i am thinking I may have a restriction in my condensor. What do you think? Thanks.
Replaced the condensor, and evacuated and put 28 oz. of freon. This time the result was constant 50 degree duct temperature. Added more freon to approximately 33-34 oz and temperature dropped to 40 degrees constant. Head pressures were high-250, low 38-40 while driving. Problem solved. Have you ever seen this before? I was using freon from a 12 oz.can. Could it be that those cans don't have a full 12 oz.? Look forward to hearing your take. Thanks.
Makes alot of sense. Thanks for all your help. I really enjoy the website and will be back again.
Suggested Repair
High side pressures were a bit high and a restriction was suspected. Replacing the condenser, evacuating, and charging closer to 33-34 oz of R-134a (instead of 28 oz) brought duct temperature to a steady 40 degrees with high about 250 and low about 38-40 while driving. Also consider a faulty low-side cycling switch, ambient temperature effects on pressure, incomplete transfer from 12 oz cans, and time for oil to circulate in a fresh system.
Conversation Summary
On a 2001 Chevy 1500HD with a new GM compressor, drier, and orifice tube, the A/C was about 40 degrees at idle but rose toward 50 degrees while driving. Idle pressures were about 290 high and 52 low on a 92-degree day, and about 260 high and 45 low at higher RPM; the compressor cycled but not in the expected low-side range. The expert said pressures were high, a restriction was possible, and a bad low-side cycling switch can cause improper cycling. After the condenser was replaced, 28 oz still gave a constant 50 degrees; adding refrigerant to about 33-34 oz dropped it to a constant 40 degrees with acceptable driving pressures. The expert noted ambient temperature and charge amount affect pressures, oil may need time to circulate, and cans may not deliver a full 12 oz. The owner confirmed the system was then cooling well.
