1999 Chevy Prism Blower Only on High
1999 CHEVROLET
MIKE9
  • 5 POSTS
AC & Heater only work in hi position. Is is blower motor?, blower resistor?, relay?,switch, or what?
Thanks for your insight...
Dec 11, 2006 at 3:40 AM
CARUNDELL
  • 602 POSTS
[quote:90b5daa917="mike9"]AC & Heater only work in hi position. Is is blower motor?, blower resistor?, relay?,switch, or what?
Thanks for your insight...[/quote:90b5daa917]
Hey mike,
More than likely the blower resister, some models were changed to the solid state style and not the old wire resistor style and they fail quite often.
Chris
Dec 11, 2006 at 4:35 AM
MIKE9
  • 5 POSTS
Thanks Chris. That's good to hear since I was thinking that if the resister failed it might be due to a bad blower with lower than acceptable resistance forcing me to get a new blower motor as well. I hope that you are right . How common is it that you need to replace both the blower motor as well as theresister?
Dec 11, 2006 at 5:00 AM
CARUNDELL
  • 602 POSTS
Mike,
Not very common, and a good indicator that all is ok is that your blower works fine on high speed. It is pretty common for those resistors to go as they are solid state and were not sealed very well and the slightest bit of moisture would cause corrosion and failure
Chris
Dec 11, 2006 at 5:12 AM
MIKE9
  • 5 POSTS
Many thanks foryour sound advice!!!
Dec 11, 2006 at 5:25 AM
CARUNDELL
  • 602 POSTS
My Pleasure Mike!!!! And pass the word around about this forum !!! The more the merrier!!!!
Dec 11, 2006 at 5:28 AM
MIKE9
  • 5 POSTS
Will do!! Thanks again!
Dec 11, 2006 at 6:54 AM
MIKE9
  • 5 POSTS
Hey Chris & Carundell :D ,
Just wanted to let you know that you were absolutely right!! Replaced the Blower Motor Resistor and everything works fine. There was an open circuit in the blower resistor.
You reallly know what you're talking about!
This is an amazing and excellent service that you provide. Happy Holidays!!!!
Mike
Dec 13, 2006 at 3:50 AM
CARUNDELL
  • 602 POSTS
[quote:2445b358ab="mike9"]Hey Chris & Carundell :D ,
Mike[/quote:2445b358ab]
Mike,
Thanks so much! All these guys here are great, they really know what its all about.
Chris
Dec 13, 2006 at 8:33 AM
Suggested Repair
Replace the blower motor resistor. High speed working normally indicates the blower motor is usually fine, so both parts rarely need replacement. An open circuit in the resistor was confirmed and replacement restored all speeds.
Conversation Summary
A 1999 Chevy Prism with about 49,000 miles had AC and heat blower operation only in the high position. The expert said the solid-state blower resistor commonly fails from moisture and corrosion, and that a working high speed is a good sign the blower motor is okay. The owner replaced the resistor, found an open circuit, and reported that all speeds worked again.
