2001 Chevy 1500HD AC Warm at Speed
GBGTEXAS
  • 46 POSTS
2001 Chevy 1500HD, 108,000 miles, 6.0 liter
Compressor, drier, orfice tube are new. System has been flushed and evacuated for 2 hours. 28 oz. of freon and PAG oil. Problem - a/c temperature at idle is fine (40 degrees) but rises toward 50 degrees when RPM's are raised during normal driving. Do you have any ideas? a/c is just not performing at peak performance. Thanks!
Jun 30, 2007 at 3:44 PM
2CARPRO JACK
  • 11,533 POSTS
What are the pressures at idle. then at rpm? What parts did you use? OEM? Does the compressor ever cycle?( turn off an on)
Jul 1, 2007 at 1:31 AM
GBGTEXAS
  • 46 POSTS
[quote:e68dd896c3="2CarPro Jack"]What are the pressures at idle. then at rpm? What parts did you use? OEM? Does the compressor ever cycle?( turn off an on)[/quote:e68dd896c3]readings at idle are:
high side - 290 on a 92 degree day. Low side - 52
With rpm's - high - 260
low - 45
I even tried to lower the freon level but I think my low side is still too high. Shouldn't it cycle between 25-40. Used a new GM compressor and it does cycle, just not in the right range. i am thinking I may have a restriction in my condensor. What do you think? Thanks.
Jul 2, 2007 at 1:30 PM
2CARPRO JACK
  • 11,533 POSTS
Pressures sound a bit high. Could very well have a restriction somewhere. When does the comp cycle? have seen the low side cycling switches go bad and make the comp cycle
Jul 3, 2007 at 12:48 AM
GBGTEXAS
  • 46 POSTS
[quote:aa6865b3e0="2CarPro Jack"]Pressures sound a bit high. Could very well have a restriction somewhere. When does the comp cycle? have seen the low side cycling switches go bad and make the comp cycle[/quote:aa6865b3e0]
Replaced the condensor, and evacuated and put 28 oz. of freon. This time the result was constant 50 degree duct temperature. Added more freon to approximately 33-34 oz and temperature dropped to 40 degrees constant. Head pressures were high-250, low 38-40 while driving. Problem solved. Have you ever seen this before? I was using freon from a 12 oz.can. Could it be that those cans don't have a full 12 oz.? Look forward to hearing your take. Thanks.
Jul 6, 2007 at 3:03 PM
2CARPRO JACK
  • 11,533 POSTS
Ambient temps can change a/c pressures as well as amount of 134a. Also sometimes a fresh system needs a little time for th eoil to circulate around the system and settle into the appropriate places. I doubt if you could ever get all the 134a out of a can,seem to me there would be a little left in it, due to the fact it has to have some amount of pressure due to the pressure in the system. Make sense to you? anyway, glad to hear your basking in cold air again
Jul 7, 2007 at 12:59 AM
GBGTEXAS
  • 46 POSTS
[quote:7031331e04="2CarPro Jack"]Ambient temps can change a/c pressures as well as amount of 134a. Also sometimes a fresh system needs a little time for th eoil to circulate around the system and settle into the appropriate places. I doubt if you could ever get all the 134a out of a can,seem to me there would be a little left in it, due to the fact it has to have some amount of pressure due to the pressure in the system. Make sense to you? anyway, glad to hear your basking in cold air again[/quote:7031331e04]
Jul 7, 2007 at 7:34 AM
GBGTEXAS
  • 46 POSTS
[quote:4026080746="gbgtexas"][quote:4026080746="2CarPro Jack"]Ambient temps can change a/c pressures as well as amount of 134a. Also sometimes a fresh system needs a little time for th eoil to circulate around the system and settle into the appropriate places. I doubt if you could ever get all the 134a out of a can,seem to me there would be a little left in it, due to the fact it has to have some amount of pressure due to the pressure in the system. Make sense to you? anyway, glad to hear your basking in cold air again[/quote:4026080746][/quote:4026080746]
Makes alot of sense. Thanks for all your help. I really enjoy the website and will be back again.
Jul 7, 2007 at 7:36 AM
Suggested Repair
High side pressures were a bit high and a restriction was suspected. Replacing the condenser, evacuating, and charging closer to 33-34 oz of R-134a (instead of 28 oz) brought duct temperature to a steady 40 degrees with high about 250 and low about 38-40 while driving. Also consider a faulty low-side cycling switch, ambient temperature effects on pressure, incomplete transfer from 12 oz cans, and time for oil to circulate in a fresh system.
Conversation Summary
On a 2001 Chevy 1500HD with a new GM compressor, drier, and orifice tube, the A/C was about 40 degrees at idle but rose toward 50 degrees while driving. Idle pressures were about 290 high and 52 low on a 92-degree day, and about 260 high and 45 low at higher RPM; the compressor cycled but not in the expected low-side range. The expert said pressures were high, a restriction was possible, and a bad low-side cycling switch can cause improper cycling. After the condenser was replaced, 28 oz still gave a constant 50 degrees; adding refrigerant to about 33-34 oz dropped it to a constant 40 degrees with acceptable driving pressures. The expert noted ambient temperature and charge amount affect pressures, oil may need time to circulate, and cans may not deliver a full 12 oz. The owner confirmed the system was then cooling well.
