1999 Chevrolet Truck Stalls
NATERZR2
  • 9 POSTS
Bought it used with 59K miles and it started stalling within 2 months. It usually seems to happen as the car is warming up, but has happened after 2 hours of continuous driving as well. It is so random, it is really hard to narrow down. It may not stall for 3 months, then 1 week straight it stalls everyday. It can happen when accelerating or running a constant speed. It will act up in warm or cold weather. The RPM's usually sputter for about 10 seconds, then it may drive normal or it will completely stall. I have had the fuel filter, spark plugs and wires, dist. cap and rotor replaced. Dealership said there are no error codes and the fuel pressure is fine. Please help, for I feel I'm chasing a ghost.
So I put new catalytic converters in on 4/3/06. Check engine light has not come on and it's running great. Old converters were hollowed out, had holes in them, and the guts were found plugging up the muffler.
Question is, how could they have gotten so bad after only 80K+ miles? Should I be worried that this may happen again soon? Can you check the gas/air mix, even though the check engine light isn't on?
Mar 22, 2006 at 11:39 PM
2CARPRO BOB
  • 45 POSTS
This is common when you have a vacuum leak or the throttle bore needs to be serviced here are three guides to go over when fixing the problem.
and
https://www.2carpros.com/articles/stall-at-idle
and
Mar 26, 2006 at 1:17 PM
NATERZR2
  • 9 POSTS
The mechanic said that the fuel pump can actually be intermittent, which was a surprise to me. I thought they either worked or not. I took it to the shop during the week becasue it started sputtering again, and they couldn't find anything wrong and as soon as I drove it off the lot, the damn 'service engine soon' light came on. I dropped it off over the weekend AGAIN, so we'll see what shows up.
Appreciate the feedback.
Mar 26, 2006 at 11:04 PM
NATERZR2
  • 9 POSTS
Here is the latest update:
After getting new catalytic converters put in and a new muffler, car worked great. Then a week later, drove it for 245 miles and it sputtered 5-6 times down the highway at 75 mph, and backfired hard. Check engine light came on. Took it to a different dealership this time. They said it was a catalytic converter code again. They did notice that the distributor drive gear was pretty worn. Got that replaced. Worked fine for a day. Now it stalls after I put it into gear. Once driving, seems fine, only after I start it up and put it into gear it stalls.
Apr 19, 2006 at 6:27 AM
CAVALIER
  • 16 POSTS
Try cleaning out the air intake on the throttle body and as far in as you can reach. Lots of crud builds up after time.
I just recently had a problem sputtering and stalling and then stalling once put into gear. this fixed it.
Apr 20, 2006 at 10:38 AM
NATERZR2
  • 9 POSTS
SOLVED! it was the crankshaft position sensor.
Apr 24, 2006 at 12:15 AM
2CARPRO BOB
  • 45 POSTS
good to hear please use 2Carpros.com anytime .
Jun 14, 2021 at 2:47 AM
Suggested Repair
Replace the crankshaft position sensor, which the owner confirmed stopped the random stalling. Also check for vacuum leaks and clean throttle-body deposits, as those were suggested during diagnosis.
Conversation Summary
A 1999 Chevrolet truck would start but not stay running, with random sputtering and stalling while warming up, accelerating, or cruising, in warm or cold weather. The fuel filter, spark plugs and wires, distributor cap and rotor, catalytic converters, muffler, and a worn distributor drive gear were replaced; fuel pressure was reported normal and codes were inconsistent. A shop noted the fuel pump can fail intermittently, and guidance included checking vacuum leaks and cleaning the throttle body. After further stalling when shifted into gear and highway sputtering with a hard backfire, the owner reported the problem was solved by replacing the crankshaft position sensor.
