1998 Chevrolet K1500 Turn Signals Out
Suggested Repair
Check the under-hood fuses as well as the fuse panel and flasher. If those are good, suspect the turn signal switch. Remove the plastic steering column cover and check for power with the signal off, then turn left and right to see whether other wires power up. Replacing the signal switch is a fairly easy job that typically takes less than 30 minutes.
Conversation Summary
The owner of a 1998 Chevrolet K1500 reports turn signals that stopped working even though the bulbs and hazard lights still work. A new flasher restored the signals for about an hour, and the fuses and flasher tested good. The expert says a dead indicator points to a fuse or the signal switch, notes there are additional fuses under the hood but does not recall a dedicated turn-signal fuse, and recommends removing the steering column cover to check for power as the switch is moved left and right.
