1993 Chevy Truck turn signals
200,000 MILES • V8 • 4WD • AUTOMATIC
DENNIS6499
my turn signals don't work. I need to remove the ignition switch so that I can get to the turn signals to see why they are loose and not working. They seem to have something broken inside as the turn signal lever is hanging loose.
Aug 15, 2009 at 6:47 AM
JDL
  • 16,098 POSTS
Hello, my info shows, you don't have to remove the ignition switch or lock cylinder to remove the turn switch? Maybe I'm looking at the wrong info? You do have to remove the steering wheel, if there is an air-bag, you need to disarm it, so it doesn't blow-up in your face.
Aug 15, 2009 at 7:57 AM
