96 lumina cutting off
VANMAN42
  • 23 POSTS
My aunt has a 96 chevy lumina that cutting off riding down the road, she has to wait about 10 mins. for it to crank ,the longer it runs the more it cuts off,it been to the dealer,been tuned up.What could cause this?
Jun 10, 2006 at 1:31 PM
MNEWGUY39
  • 7 POSTS
CHECK THE RELAYS FOR THE IGN. SYSTEM.
THEY ARE UNDER THE HOOD, NOT IN THE FUSE BOX.
THERE SHOULD BE ONE BOX UNDER EACH CORNER SUPPORT UNDER THE HOOD.
1 IS RIGHT NEXT TO THE BATTERY AND THE OTHER IS RIGHT NEXT TO THE RADIATOR RESEVOIR.
AS THEY HEAT UP THEY MIGHT BE FAILING.
NORMALLY WHEN YOU TAKE A VEHICLE TO A DEALER IT SITS THERE A WHILE AND THIS PROBLEM MIGHT NOT GET SEEN.
Jun 13, 2006 at 5:39 AM
