THE FACTORY RECOMMENDS REMOVING THE BODY FROM THE FRAME WITH A TWO-POST SIDE LIFT, THAT IS BEYOND THE TOOLS I HAVE. IS THIS PROCEDURE NECCESSARY OR CAN THE ENGINE BE REMOVED WITHOUT THIS PROCEDURE?
1996 Chevrolet Astro Engine Replacement Fix
Good luck, let us know how it goes.
Ps with this amount of work, do not cheap out. Install a new water pump, have your alternator rebuilt or buy a new one. Buy or replace all your emission hoses with new. Replace all your water hoses with new. Make sure your clutch fan is operating properly.The added cost and hassel may seem too much, but it is all 100% worth it for trouble free operation.
Ken
Suggested Repair
The engine can be removed from the front without lifting the body off the frame. Remove the bumper, grille, radiator, and radiator support, leaving the fenders in place, and pull the engine with a hoist. If the radiator support is one piece, strip the engine down except for the intake manifold and oil pan, then carefully thread it through the opening with a helper and protective wood. While the engine is out, replace the water pump, water hoses, and emission hoses, service or replace the alternator, and verify the clutch fan works.
Conversation Summary
The owner of a 1996 Chevrolet Astro with a blown 4.3L V6 asked whether the body must be lifted off the frame to replace the engine. Replies said the engine can be pulled through the front on the ground after removing the bumper, grille, radiator, and support. One contributor described threading a stripped engine through the radiator support opening and recommended renewing the water pump, hoses, and alternator and checking the clutch fan.
