Motor hesitates under low RPM load. Example: If I shift into 3rd at 20 MPH the motor hesiates when I try to accelerate. Once the speed picks up it runs smooth. Example: When driving at 70MPH with the cruize on and I start up a hill the engine hesiitates under the addded load, once I reach the top of the hill I can accelerate without motor heisitation. As long as the RMP'S stay high the acceleration is good, without heitation but when the motor has a load at low RPM it misses.
SPONSORED LINKS
Monday, January 11th, 2010 AT 9:11 AM
DOCFIXIT
MECHANIC
Could be several things plug, plug wire, coil, dirty fuel injector, low fuel pressure. Check engine light comming on?
Monday, January 11th, 2010 AT 9:33 AM
MIKE DUNCAN
MEMBER
Is there a way to identify the problem rather than replacing parts that might not need replacing. I'd like to narrow down the possibilities. The check engine like is not on
