95 chevy blazer
1995 CHEVROLET TRUCK
DONVROW
I have a 95 chevy blazer LS, approx 170,000 miles I cannot get it to start. it is one of the "w" vin codes, and has the OBD II system in it. It turns over and gets spark, I have put a new fuel filter in, a new fuel pump, a new fuel relay, and a new EGR valve($175). And it still will not start the fuel pressure is good. It has A CMFI fuel injection system. If we prime the engine it will start and then die. Any Ideas as to what my problem could be. When it died I had just come back from about a 150 mile drive and come around a corner and it died like it was starving for fuel. What should I check next?
Apr 21, 2006 at 2:35 AM
LOSONE
  • 1,616 POSTS
Humm Pull the plugs, put oil in all the culinders, spin the engine, put in a little more oil, spin the engine. Replace the plugs. It sounds like you might have washed the cyls with gas causing very low compression.
Apr 21, 2006 at 5:13 AM
DUDER1
  • 15 POSTS
these s-10's, and s-15's, always have this issue... i've had it myself...., check your fuse box... there should be a fuse labeled ECM, or ECM1... check it, then replace... replace it anyways.... should be a 15 amp.
THis fixed my problem... same one your having. Then, i found out that my oil sending unit was on it's way out... it was shorting out that particular fuse. I just unpluged the the wire connection at my sending unit... and it fired right up. The only other thing i think can cause this would be the modual in the distributor... but i would go with the fuse. Good luck
Apr 23, 2006 at 3:42 PM
