85 chevy c-10 305, Ignition module keeps burning out...WTF?
1985 CHEVROLET TRUCK
BAREFOOTBOB88
  • 60 POSTS
I just recently gave my truck a tune-up. Plugs, wires cap, the whole bit. The same day when I took it for a test run the ignition module burned out. Sine then I have replaced it three times after 2 burned out. The two I replaced lasted for three or four days and about 80 miles combined. Now I know that the module that the books call for my truck is either 5 pin or seven pin. Mine is neither of them. It only has four pins. The harness only has four tab connection for the module. I'm outta ideas. What is causing the module to keep frying?
Aug 1, 2006 at 8:21 PM
MATSUKES
  • 13 POSTS
Hi Bob: You helped me with my repair question the other day with my Caprice. If you run out of working Ignition Mods let me know as I purched 19 of them trying to solve my problem and they all work and have lifetime warentys They all work on 305s John
Sep 10, 2006 at 9:11 AM
