2004 Chevy Truck driving lights
106,000 MILES • V8 • 2WD • AUTOMATIC
LIGHTJOHN
I have replaced both light bulbs, but the driver's side always stops working after about a week.
Is there any way to fix this problem, or is it a fluke for Chey trucks?
John
Jul 9, 2009 at 5:49 AM
HMAC300
  • 48,601 POSTS
if he one side goes out and the other doesn't it may be a water problem. check to see if both sides have a gasket where the bulb screws in. If you are seeing moisture in the driver's side then that is your problem and youneed to find wher eit is coming in.
Sep 10, 2009 at 8:14 AM
