2004 Chevy Truck
WRECKTRUCK1
  • 2004 CHEVROLET TRUCK
Electrical problem
2004 Chevy Truck V8 Four Wheel Drive Automatic
HOW DO YOU CHANGE LEFT FRONT TURN SIGNAL BULB?
Thursday, January 28th, 2010 AT 9:14 AM
TOOOMANYTOYS
  • 513 POSTS
The easiest way to get to the bulb is to remove the headlight. There are two pins that hold the headlight in. They unclip then pull out. Once headlight is out. Remove the turn signal bulb socket. Then pull out the bulb and change.
Thursday, January 28th, 2010 AT 9:40 AM
