2004 Cavalier P0141 Oxygen sensor
FREDNJESS
I've got a 2004 Cavalier 2.2 L with a P0141 code. I know it's the oxygen sensor, but want to make sure that I'm looking in the right place. It should be on the exhaust header, inside the engine bay, right?
Also, I just had it in the Chevy dealership to replace the ignition module, new plugs, and they fixed the fuel injectors. That was 4 days ago.
Thanks for the help,
Fred
Feb 10, 2007 at 12:17 PM
CHEVY22
  • 1,375 POSTS
HEY THERE , IF YOU JUST HAD INJECTOR WORK AND A TUNE UP I WOULD RESET THE PCM BEFORE CONDEMNING THE 02 ,THE WORK PERFORMED MAY HAVE CAUSED THIS CONDITION ESPECIALLY IF YOU HAD A FUEL INJECTOR SERVICE DONE,IF YOU DONT HAVE A TOOL TO RESET THE COMPUTER YOU CAN PULL THE NEGATIVE CABLE OFF FOR 15 MIN
JIM
Feb 15, 2007 at 6:17 AM
