i replaced the battery and now it starts and dies after 2 seconds.
Jan 3, 2008 at 5:52 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
BLACKOP555
CAR REPAIR CONTRIBUTOR
first remove the air intake hoses and have someone start the car and give it half throttle, after it starts to die, give it a little bit of starting fluid, if it stays running untill it runs out of starting fluid then you should check the fuel pump.
