2002 Chevy Truck R&R starter, now no fire at plugs
140,000 MILES • V8 • 4WD • AUTOMATIC
LGUNN
My starter was bad. I replaced the starter which now turns over good however truck will not start and i have no fire at the plugs. There are wires in the starter wire loom that branched off to a sender in the pan and a set that went to what looked like the bellhousing. these wires look ok but may have been damaged inside. What are these wires for and can they keep the truck from starting? Thanks in advance. Larry
Nov 25, 2009 at 12:19 PM
MERLIN2021
  • 17,250 POSTS
Check the ones to the bell housing, could be the crank sensor, thats where the signal for spark originates...You may have knocked the connector loose, or off, or crushed a wire or damaged the sensor by hitting it with the new or old starter.
https://images.2carpros.com/forum/automotive_pictures/62217_ckp_3.jpg
Nov 25, 2009 at 10:10 PM
