2000 Chevy Malibu Delayed Dash Power
BILLVYHO
  • 11 POSTS
2000 Chevy Malibu, 93000 miles; Sometimes (most times) when I start my car, the DRL's, Instrument Panel lights, HVAC, power windows, gas guage, and temp guage are not working. They start working after about 5 minutes. Everything else seems to work. I went on an hour trip the other day, and the same things were coming off and on during the trip. Can someone point me in the right direction on what to look for to fix this. Thanks!
May 10, 2007 at 4:48 AM
BILLVYHO
  • 11 POSTS
I just noticed something else....the red light behind the PRDN321 also fails to come on with the rest of the stuff, but the PRND321 are lit.
May 16, 2007 at 12:51 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a main power relay or possibly ignition switch. When stuff isnt working, grab a test light and check for power at the appropriate fuses. If none then feed problem if it has power then problem is between the fuse block and dash
May 17, 2007 at 1:07 AM
Suggested Repair
Suspect the main power relay or ignition switch. When the accessories are not working, use a test light to check for power at the related fuses. No power indicates a feed problem; power present points to a fault between the fuse block and the dash.
Conversation Summary
A 2000 Chevy Malibu with 93,000 miles often starts with the DRLs, instrument panel lights, HVAC, power windows, fuel and temperature gauges, and the red PRNDL indicator not working. They usually begin working after about five minutes and can also cut in and out while driving. The expert suggested a main power relay or ignition switch and recommended checking fuse power with a test light to determine whether the fault is in the feed or between the fuse block and dash.
