My c/k 3500 7.4 hesitates for a short while after restarting from refueling. It also loses power under heavy load. I pull boats that weigh up to 14,000 lbs. And it only seems to lose power while pulling the heavier boats or when heading into a stiff wind. I have replaced the fuel pump with a Bosch when it failed and have replaced the pre cat o2 sensors with OEM. I get a lean mix code from time to time that does not correlate to the loss of power. The truck runs fine as soon as I unhook from the load. MAF? ECM/PCM? Failure.
SPONSORED LINKS
Saturday, October 24th, 2009 AT 8:48 AM
