1999 Chevrolet Tahoe Acceleration Bog
TCORBITT20
I have a 1999 Chevrolet Tahoe 4wd with the 5.7 liter v8 with 133,000 miles. I recently began having trouble when I accelerate from stop. As I press the accelerator, it feels as if the engine is "bogging down" and continues until I let off and accelerate slower or until you hear and feel a thump. I've replaced all of the spark plugs, wires and fuel filter, but the problem still persists. What else should I consider? Thanks for the help.
Jan 23, 2007 at 6:19 AM
CHEVY22
  • 1,375 POSTS
if you dont have a ses light on i would start by checking the fuel pressure and watching the bleed down , you may have poppet valve stuck or a fuel pressure regulator problem
lmk
jim
Feb 16, 2007 at 6:29 PM
DAVIDGLZ
[quote:761a77aeac="tcorbitt20"]I have a 1999 Chevrolet Tahoe 4wd with the 5.7 liter v8 with 133,000 miles. I recently began having trouble when I accelerate from stop. As I press the accelerator, it feels as if the engine is "bogging down" and continues until I let off and accelerate slower or until you hear and feel a thump. I've replaced all of the spark plugs, wires and fuel filter, but the problem still persists. What else should I consider? Thanks for the help.[/quote:761a77aeac] i got the same problem before you need to change distrubuitor cap and the rotor too
Aug 18, 2007 at 4:48 PM
JOHNCOBB
i also have a 1998 tahoe and seems to do the same thing but only occurs when it gets warmed up. all o2 sensors have been changed and fuel filter, convertors checked out fine also what could it be.
Apr 20, 2008 at 5:05 AM
Suggested Repair
With no SES light, check fuel pressure and how quickly it bleeds down. A stuck poppet valve or a faulty fuel pressure regulator may be causing the bog on acceleration.
Conversation Summary
A 1999 Chevrolet Tahoe 5.7L bogs when accelerating from a stop until the throttle is eased or a thump is felt. Plugs, wires, and the fuel filter were already replaced. An expert advised checking fuel pressure and bleed-down for a stuck poppet valve or fuel pressure regulator if no SES light is present. Another owner suggested a distributor cap and rotor, and a 1998 Tahoe owner reported a similar warm-engine symptom after replacing oxygen sensors and the fuel filter.
