Sounds like a bad connection in your main cables coming from the battery, or the cables themselves?
You clean the cable ends real good at the battery terminals? If you have a VOM check for resistance between the battery neg lug and a good ground ( like the alternator case). And check between the positive lug and starter bolt.
Or bypass the cables with a set of jumper cables.
SPONSORED LINKS
Wednesday, October 18th, 2006 AT 10:45 PM
