1997 Chevy Truck wire short
1997 CHEVROLET TRUCK
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
HASEK
heater switch won't engage when ABS light is on.
restarting ignition switch will at times start heater switch.
Mar 18, 2009 at 4:32 AM
PREID
The problem is your ignition switch. I have a '97 K3500 that was doing the exact same thing except the 4wd would be disabled when the ABS light was on, which was all the time, and (after much wasted time on other things), I replaced the ignition switch module and everything works. These years of trucks had poor ignition switches. Good luck!
Apr 2, 2009 at 3:55 PM
