Fuel Pump Relay
YOLLUP
I checked ignition and there was no spark.I checked fuse panel under the hood on fender well and found that ecm-1 fuse had no power.I supplyed power to it, truck started and my dash warning lights where working. Where should I start looking for the open circuit.
Sunday, November 4th, 2018 AT 12:34 PM (Merged)
Found that ecm-1 fuse had no power.I supplyed power to it
The power to the ECM-1 fuse comes from the ignition switch. The only time it has power is when key is at On or Start position.
TODD LUCAS
  • 8 POSTS
  • 1997 CHEVROLET TRUCK
1997 Chevy Truck
Is the fuel pump supposed too kick in everytime u turn the key on if so what would cause it not to.I replaced the relay.I'm having to prime engine to start after it sets overnight. Fuel pump only kicks in maybe 2 out of 5 times.
YOLLUP
Thanks I found the problem. The contact in the key switch was burnt.
WRENCHTECH
  • 20,761 POSTS
Yes, it's supposed to energize for 2 seconds when the key is turned on. If it's not doing that, then you could have a problem with the fuel pump relay. This truck can run without a relay after a long crank because it has a redundant fuel pump power supply through the oil pressure switch.
I would need the model and engine size to check the wiring diagram to make sure they share the same fuse.
TODD LUCAS
  • 8 POSTS
Engine 5.7 and 1500 series
WRENCHTECH
  • 20,761 POSTS
Yes, one fuse feeds both the relay and the oil pressure switch so that is not your problem.
https://www.2carpros.com/forum/automotive_pictures/561653_fuel_pump_97_1500_57_1.jpg
TODD LUCAS
  • 8 POSTS
So I could have a faulty relay or what should I check?
WRENCHTECH
  • 20,761 POSTS
Yes, I gave you the diagram so you could test the circuit but the relay is very likely.
TODD LUCAS
  • 8 POSTS
Replaced fuel relay and still can't get fuel pump to kick in every time I cycle key any suggestions?
WRENCHTECH
  • 20,761 POSTS
Yes, test the circuit as I advised the first time, I gave you the wiring diagram.
JOE M.
  • 1989 CHEVROLET TRUCK
Hi just got the truck last week
and even my insurance agent was impressed
it was a 1 owner and only has 101,000
(350 or 5.7 with OD auto trans)
ok anyway which leads to my problem
i just put a cat back system in it
and while under the truck I could hear the fuel pump humming away key off and not even in the ignition
i was thinking fuel pump relay possibly stuck?
But I cant seem to find it
i went back to the prior owner
he's trying to find the owners manual for me
(their in their 60's and seems the Mrs. Took it out to read and never put it back)
all help would be greatly appreciated, Thank U all, signed Joe M.
Sunday, November 4th, 2018 AT 12:35 PM (Merged)
DAVE OTT
  • 5 POSTS
It should be on the passenger side on firewall next to blower motor. At least that is where mine is on my 89 chevy
JDL
  • 16,098 POSTS
How many gas tanks do you have? With one gas tank only one relay that I know of. Could be an oil pressure switch in parallel with the relay. It's a redundant power supply to the pump, the switch and relay should have no effect on each other.
BOBFRANK
  • 6 POSTS
  • 1990 CHEVROLET TRUCK
Electrical problem
1990 Chevy Truck V8 Two Wheel Drive Manual
Have a 1990 3500 chevy truck. Fuel pump runs with key off. It will shut off after 5-10 minutes. Misses while idling. Have check relay and fuse. Both good. Where is fuel pump oil pressure switch and could a faulty one be causing this?
BOWTIE BABY
  • 101 POSTS
I dont know what you meen by fuel pump oil pressure switch. The electric pump will have a fuel pressure switch built in. Have you checked the ignitioon switch and ignition relays.
BOBFRANK
  • 6 POSTS
Oil pressure switch is located behind distr. Unhooked it and fuel pump shuts off. Put new one on and pump is doing same thing. Showed high oil pressure all the time, then when I unplugged it it showed hi pressure at start up and then none when key off. With new switch, it shows 60 lb at start up and bleeds down to half way when key shut off. Also check gauges lite is coming on with new switch.
BOWTIE BABY
  • 101 POSTS
If your check guages lite is coming on it will store fault codes in the computer. You can pick up a scanner for about $30. That will help you pinpoint the problem more accurately.
BOBFRANK
  • 6 POSTS
[Computer will not store codes as I have to unhook bat cable for pump to shut off. Replaced ignition switch and it is still doing it. When I unhook ing switch the pump runs right. Help
BOWTIE BABY
  • 101 POSTS
Wow thats a weird one. Did you ever have any wiring problems in the past, wires melted together or anything like that. Maybe you got a bad switch from the parts store.
