1995 Chevy Truck chevy 2500 truck weak steering.
21,300 MILES • V8 • 2WD • AUTOMATIC
ZACH323
my steering seems to be getting weak. when i make a right turn, the wheel starts to move towards the right all by itself. And going down the highway it seems to drift to the right. When I go over rougher terrain, the steering wheel gets very jerky
Feb 15, 2009 at 2:48 AM
MIKE H R
  • 3,094 POSTS
check the front allignment. and wheels. what it sounds like is the right front is out of allignment. does it pull to the right when you put on the brakes?
Feb 15, 2009 at 3:14 AM
ZACH323
it does pull to the right when it hit the brakes.
Feb 15, 2009 at 3:46 AM
MIKE H R
  • 3,094 POSTS
check the calliper on the right side. made sure the wheel turns freely. if while turning the wheel it grabs in areas then the rotor should be checked to.
Feb 15, 2009 at 1:12 PM
