Ac was working fine, then compressor stopped. I checked and sytem has pressure so recharge is no the issue. How can I test AC compressor clutch and or trouble shoot sytem?
Thank you
Brad
Wednesday, June 18th, 2008 AT 7:18 PM
OBXAUTOMEDIC
MECHANIC
Find you A/C Relay check numbers then look for similar looking relay and check for same numbers swap relays if works replace relay if not check Clutch Cycling Switch.
