1991 Chevy Truck Air conditioner shuts off
CHEVYMAN1320
  • 1991 CHEVROLET TRUCK
  • V8
  • 4WD
  • 183,000 MILES
I have a 91 chevy 1500. When I turn the air on it blinks at me. So I unpluged the wires behind the glove box to make sure the conection was good. Then I turned on again the compressor cycled 8 times then the light on the dash blinked at me again and the compressor stoped kicking on. So ever time I unplug the wires to reset ac controls it cycles 8 times and shuits off and light blinks at me. Any ideas.
Tuesday, June 17th, 2008 AT 4:17 PM
DOCFIXIT
  • 18,828 POSTS
Low 134a find the low pressure cutout switch on the accumulater pull the trem jumper the thing if comp works and it stops blinking you have your sloution. Fill ur up then check for leaks.
Good luck
Tuesday, June 17th, 2008 AT 4:37 PM
