1995 Chevy Truck 4wheel drive
FORDMAN250
  • 1995 CHEVROLET TRUCK
  • V8
  • 4WD
  • MANUAL
  • 137,000 MILES
When I pull the transfer case shifter from 2wheel to 4 wheel, the front axles don't engage. Was told the actuator tested bad. Where is actuator located and does it lock in the front axle?
Thursday, January 8th, 2009 AT 5:49 PM
  • 109,874 POSTS
I believe it is located on the top portion of the transfer case, and yes it can cause the problem. It allows vacuum to go to the fron axle and engage the 4wd.
Here is a picture if what you are looking for.
https://www.2carpros.com/forum/automotive_pictures/249084_drm600101003_1.jpg
I hope this helps. Let me know if you have other questions.
Friday, January 9th, 2009 AT 11:34 PM
