2001 Chevy Truck Rear Diff.
BOOM3471
Drive Train Axles Bearings problem
2001 Chevy Truck V8 Four Wheel Drive Automatic 115K miles
The rearend made a noise and then it would not go forward. I put it in 4H and it will drive fine with front wheel drive. do you think it's in the rearend or transfer case? If it's the rearend do you know what it could be? thanks for your help
Mar 25, 2009 at 11:00 AM
DCS1998
  • 41 POSTS
First,
Jack the rear of the truck up (both tires off the ground) turn one rear tire and watch to see if the other one turns in the opposit direction. If it dosent, its something like a spider gear pin or a gear broken in the rearend.
Then come on back and tell us what you found out.
Mar 26, 2009 at 4:21 AM
BOOM3471
Ok, Thanks for your help and I will get back in touch.
Mar 26, 2009 at 4:29 AM
