1994 Chevy Truck 6.5 turbo diesel
BOSS75
  • 1994 CHEVROLET TRUCK
Engine Mechanical problem
1994 Chevy Truck Four Wheel Drive Automatic 130000 miles
read your reply. Never sprayed starter fluid. Lite comes on normal sounds normal. Connot find glo plug fuse. How can I trouble shoot power to glo plugs. You suggested that might be the problem, so do i.
Tuesday, March 11th, 2008 AT 8:48 PM
2CARPRO JACK
  • 11,533 POSTS
The fuse should be labeled, it is in the fuse panel - 5 amp. There are also 2 fusible links off the "glow Plug Control Realy" (top right rear of engine) Use a test light to check these things.
Wednesday, March 12th, 2008 AT 7:59 AM
