The 5.3 and your existing engine share nothing in common for the most part. You will require a custom ECM and wire harness, transmission controller/harness (if automatic), flexplate and spacer (if automatic), engine mount adapters, fuel system upgrade, and front end accessory drive components. Many of these items are available from the aftermarket such as www. Hotrodlane. Cc. This will be a pretty in depth swap, why a 5.3L and not a 88-95 or 96-00 350 swap?
I am not aware of a TBI intake for the LS series engines (doesn't mean there isnt though). GM sells a TBI to Vortec intake, but this is referring to the Vortec heads used from 96-00, not on the LS series engines.
42 °
SPONSORED LINKS
Wednesday, December 9th, 2009 AT 11:46 AM
