Engine Performance problem
1994 Chevy Truck V8 Two Wheel Drive Automatic
i need to know where to disconnect the control module power source
Friday, July 17th, 2009 AT 2:19 PM
DR LOOT
MECHANIC
Open your hood you will find the cruise control on the left fender, remove the electrical plug and that should do it.
SPONSORED LINKS
Saturday, July 25th, 2009 AT 3:14 PM
MATTYSGIRL
MEMBER
If I read your question correctly, your looking for your electronic control module (ecm) not your cruise control(?) And that would be located behind your kickplate on the passenger side or behind the glove box on the right hand side
