I have a 1993 Chevy Corvette with 80,000 miles and auto transmission. The engine cuts out and hesitates when under a little load with a little throttle applied. Happens at all speeds even at a stop. If I give it more gas the hesitation stops. At high speeds the engine cuts out and then kicks back in. When this problem occcurs the temperature gauge goes up. First thought was that the transmission was slipping out of gear and took it to a shop. They rebuilt the transmission. Problem still existed so they drove it with a fuel pressure gauge and fuel pressure was OK. They replaced the radiator, thermostat and electronic control module and this solved the problem for a few months. It just started happening again although engine isn't running as hot as before. Any ideas?
Dec 9, 2006 at 10:25 AM
