1993 Chevy Truck
CHRISTFELCHRIS
  • 1993 CHEVROLET TRUCK
Engine Mechanical problem
1993 Chevy Truck 6 cyl Two Wheel Drive Manual
i can drive my truck down road for two miles and it drives pretty good, then it starts loosin power, like its running out of gas, then it will pick up power and lose it, I think the fuel pump or fuel filter might be bad, but don't know, can you help me out
Friday, January 22nd, 2010 AT 5:06 PM
DR LOOT
  • 2,311 POSTS
You have described your symptoms correctly, I would change the fuel filter first, then check the fuel pressure, fuel pressure should be 50 to 60 PSI.
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Saturday, January 23rd, 2010 AT 12:08 AM
