1990 Chevy Truck Misfiring
DEEBEAR67
  • 1990 CHEVROLET TRUCK
  • V8
  • 201,326 MILES
I have replaced plugs, wires, rotor cap, rotor, it still misfires when you put a load on it. Also checked for vacuum leaks. What could the problem be?
Tuesday, March 16th, 2010 AT 5:48 PM
Engine running rough or misfiring can be cause by the following-inspect and test all the following listed below:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
Tuesday, March 16th, 2010 AT 6:01 PM
