97 Chevy 350 still not running right
BOOKNEE
  • 1997 CHEVROLET TRUCK
I did the compression test to get 1 on tdc and took off cap. Rotor seemed to be lined up with my old mark and at this setting it wil start but makes a bad tapping noise. I moved distributor back one gear and forward one gear and it justs cranks with little or no spark on both positions. Moving it forward and backward moves the rotor about an 1 inch. Is that about right or could I be missing a gear in between. Ypu said it could be 180 off. Is this still possible even though it will start. Thanks Dan
Wednesday, February 28th, 2007 AT 1:38 PM
CHEVY22
  • 1,375 POSTS
Hey bock, the rotor moving that far is about righ, just for shi*s and giggled since your there try it 180 and let us know buddy, weve gotta be close
Wednesday, February 28th, 2007 AT 2:20 PM
CHEVY22
  • 1,375 POSTS
Oh and I cant remember exactly what you were doing but make sure the camsensor under the distibutor is plugged in and all other items on the tf like the tps and iac and all vacuum lines
Wednesday, February 28th, 2007 AT 2:45 PM
