It's erratic. Misses at idle. Also a little hesitation at first acceleration. Sometimes when its first started, when I put it in gear, it will shut off. No code shows. I'e changed out: spark plugs, O2 sensor, TPS, PCV valve, Idle air control valve, fuel filter, changed out 1/4m inch vacuum hose, EGR valve checked, not sticking. I'm stuck. Thanks
Aug 27, 2010 at 11:02 AM
