That is a new one for me. When you start it does it run good? Can you rev the engine a little and see how it sounds? Are you brakes locked up, or is your emergancy brake stuck (though truck should be powerful enough to push through the E-brake) tell me a little more and I will see if I can help, or make a small donation for a pro to get involved.
SPONSORED LINKS
Tuesday, November 24th, 2009 AT 8:34 PM
