1990 Chevy Truck
SCOTCH1979
  • 1990 CHEVROLET TRUCK
1990 Chevy Truck 6 cyl Two Wheel Drive Automatic
My engine died while I was driving and now I can't get it start. It cranks but it doesn't start up. What could it be?
Monday, March 16th, 2009 AT 5:23 AM
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Monday, March 16th, 2009 AT 5:28 AM
